New guy, needs help with motor choice.
jrj101
Hello, am new to boating and would appreciate any advice on this. I just bought a small pontoon boat, approx. 18 1/2 ft. Am looking at two motors. The first is a 1990 Johnson 88hp 88 special, no trim, no controls, no warranty, but runs good, and I'm told low hours. Cost $850. The second is a 1990 Johnson 40hp Tracker. Oil injection removed, don't know if that is good or bad. No trim, Comes with controls, and 6mos. warranty. Cost $900. My wife, who is frugal. Likes the 40hp, because of the warranty, much better gas mileage, [she thinks] and much cheaper to maintain. Me I like the 88hp, theory being the engine doesn't have to labor as much, power when needed, about the same gas mileage, about the same to maintain. Thanks for any advice.
wilde1j
Re: New guy, needs help with motor choice.
What's the boat rated for?
jrj101
Its not a brand name boat. It was hand built by a aircraft engineer, using aircraft material for the deck, and salvaged pontoons, and the rest new parts. Its very well built. No rating. I understand it had a 50 hp previously.
jrj101
It finally dawned on me, I placed this in the wrong forum. Sorry, I can't figure out how to move it.
93bronco
Ensign
my buddy has got a 21ft tracker pontoon with a 75hp merc tracker. he had it upgraded to the 75 from the stock 40. <br />he was very happy about that.<br />-<br />the 75hp pushes it great with 4 adults and will still pull a skier up.<br /><on a calm day><br />-<br />if you can go with the 88hp. <br /> only if it will handle it safely! <br />but if in doubt go with the 40hp.<br /><br />you will still get where ever you are going just slower.<br />its just my opinion. not worth much.
JB
Moving to Outboard General.
Jack Shellac
Well, if you're looking for a motor that's almost bulletproof, it's hard to go wrong with an 88 SPCL that's been well maintained. Mine's 12 years old and still runs as strong as the day it was new. No significant problems, either. The 40 HP of that year is a good motor, too. I prefer the larger motor, if the boat can handle it. You don't have to open it up, but it's there if you need it. <br />I wouldn't attach any significance to the oil injection being removed from the 40 HP. Everone was doing it back then, even the Coast Guard, because of the unreliability of the earlier injection systems.
