I recently purchased this 1979 Formula F18. It has a 24* deadrise and is 18ft long, has bennett trim tabs, and weighs 2600lbs. I replaced the transom and motor mounts. I also converted to center rise exhaust. I got her all back together and it ran as follows. With a no name 21p prop it ran 49-50 mph on gps at 5500rpm and the revs would have kept climbing if i let them. I tried it with a no name 23p prop that also had no cup. If anything the prop looked like it has negative cup. Anyways with the 23p I got 53mph at 5200rpm. trimming up raised rpm but not speed past that point. I know the prop choice is not ideal. I would like to put it in low to mid 60s. Where should I start and also what should I expect out of my hull?
