Stuck again, I have been attempting to install a tach on the 78 mercury 700. And it has been a PITA, after a few setbacks (type of tools to install, harness, rectifier, and wire rot). I installed the new Radio Shack rectifier, and started the motor to see if I was back to running ? charging condition. The good news was the rewire / splicing seems to work because it started. But I am concerned with charging voltage I read 16.6 at idle with muffs on. Searching this site leads me to believe it?s too high, should be more like 14.5?? The part was the one suggested here, the install was drilled and taped to old location so heat sinking should be good, I cannot find any mention of a regulator for my motor, does anyone else who did the Radio Shack mod have the same issue? is it a issue?. It was too late to try to see if the voltage would increase with throttle, assuming it would is this too much charging voltage? I am hopefully going to pre-test the tach tonight before I cut the hole. I?ll put muffs on and see if it works at idle and then rev it some to see if I get any response on the tach as well as check voltage at the batery.
Thanks
Thanks
