New Head Gasket - Sealer?
TonyinPA
Looks like the new gasket already has a sealer on one side...
Should sealer be used on either side?
(Assuming no, but want to double check)
Which side goes up?
Re: New Head Gasket - Sealer?
See the little tab on one end of the gasket ?-See if that lines up with anything on the block.
TonyinPA
Thanks! One of those Duh moments....the little tab does line it up. Can only go one way.
Barnacle_Bill
Head gaskets made now days do not require any sealant.
OptsyEagle
1/2 the world use sealant, the other 1/2 does not. All their motors seem to work fine, so flip your coin and get torqueing.
TonyinPA
I decided to go dry....made some major progress last night.
Just have some linkages to hook back up, need to finish cleaning / re-building carbs and I'll be ready for a test run this weekend hopefully.
