loco
- Joined
- Apr 25, 2010
- 154
Hi all,
So, I have a 4.3 v6 vortec. We had (salt!) water ingress from a leaky inlet manifold. Unfortunately it took a while to get the engine out, and the mechanics found some of the valve seats were shot from corrosion. So, we replaced the heads, the engineer removed the sump to clean it, then put the engine back in after blasting out all the oil channels etc.
Compression is good, and the engine starts and idles well.
We took it out for a run and after a couple miles at speed, the engine choked out and stalled. We had loads of fumes in the engine bay. It seemed to be ticking as if it was running hot. Concerned we were burning oil, we added a little at sea and thought we could hear a hiss as we did.
Looking at the gauges, it didn't appear to be running hot, with the the temp read out right in the middle (assuming I can trust it).
We limped back just above idle. The engineer suggests it must be the big end or crank bearings that have corroded and are tight which is causing the oil to cook and cause the fumes.
Thing is, the engine starts on the button and idles fine, with no noticeable rumbles or noises.
Someone I know suggested the cooling system (impeller, etc) but I'm doubting that. I might go and test the temperature of the coolant hoses.
Any other ideas what to test at this point? Current thinking is to just buy a new long engine, but I really would like to avoid the expense!
Thanks in advance!
Thanks in advance!
