goingboeing737
- Joined
- Dec 17, 2004
- 14
Hi all,<br /><br />I just picked up a 1985 4 Winns 170 Horizon w/ 140 Mercruiser. I beleive it is the Alpha 1 drive.<br /><br />First off, I need to buy a manual. Would you suggest the Seloc or Clymer? I'm pretty mechanical. Just finished restoring 2 1984 Porsches, but have never messed at all with boat stuff. Used to have a 22' with a 200 outboard, changed lower unit oil....<br /><br />The problem I'm having is with the tilt/trim. I've done a search and found "some" info, but not what I'm looking for.<br /><br />Tilt will go down, but not up using the toggle switch on the throttle. It will go up with the trailer switch however. Do not hear any clicking on the pump solinoid when trying to go up with the toggle switch. I'm going to check, but kind of figure it's a bad "up/out" solinoid. Does the trailer button bypass the solinoid somehow?<br /><br />The biggest problem however is the wiring from the pump to the trim limit and trim indicator switches on the drive. They are in the worst shape I've ever seen electical wires. Dried, cracked, frayed, exposed, corroded, brittle....Every other wire in the boat looks new/perfect. The wires are no longer connected to either of the of the switches on the drive. They are broken off a couple of inches behind the drive. I think I will have to replace both of the switch/indicators.<br /><br />The wiring seems to be somewhat modular, in that I think I can replace the section between the pump and the switches. Is there any way to "snake" or pull the wires through the transom without pulling the lower unit off? I can get to both switches by turning the drive full each way, but can not see exactly where the wires come through the transom. I have been to the MercStuff site and seen a pdf of the Merc manual, they show pulling the unit to get the wires through.<br /><br />I could probably live with it the way it is, but I'm trying to teach wife and daughter how to drive a boat. Having a working trim/tilt indicator would be a real plus.<br /><br />Anybody here in the north Houston or Lake Livingston area?<br /><br />Sorry about the long post. Thanks in advance for your help.
