Re: New here with a Force 120
Matt,
I too am new to the boating world, this month in fact. I purchased the same boat as you (89 Bayliner Capri L drive) because it was a great deal!....After much belated research I realized this was not the best boat to purchase, it did however fit my first boat purchase price point (under 3K) I was excited on the deal I got...only to find out that the L-Drive was a dead idea only a few years after it was originally introduced :'(. Force, is no longer, purchased by Mecury and is no longer supported (parts are not available from them and used stuff is pretty hard to find).. Sounds like your boat could have coil pac problems or something like my boat had....a bad flywheel and trigger assembly. The ignition system on the L-drive runs off maginets on the flywheel which powers up the coilpacks. As you advance the throttle to the carbs the trigger assembly advances the spark to the cylinders. if the flywheel/trigger assemblies goes bad...no spark. I would suggest checking your flywheel (it requires a special puller as the shaft is tapered) Check out the flywheel and trigger assembly for abnormal wear or obvious damage that is where it starts. I was lucky and found a used flywheel, trigger assembly from a local guy. My goal is to fix this and sell it and buy a better setup. Not to mention it's a 2 stroke engine and will most likely be outlawed in most areas like it has in mine :%.
