I have a 2008 Horizon 180 I recently purchased. I want to add an hourmeter close to the other gauges since there is a perfect spot to install there. I tested the fuse block under the dash and every fuse position has power all the time (after adding a fuse) even with the key off.
Where should I wire to? I must be missing something... thanks!
Also, is it possible to use a scan tool to read the current hours on the engine? (2008 VP 3.0 GLP-J)
