handle
- Joined
- May 7, 2012
- 104
Installing a new hub, 1250# onto a 1" sraight shaft, directions say to tighten the nut down to 30/40 ft. lbs. while turning the hub to ensure the bearings are properly seated. Loosen nut and finger tighten. Does that sound about right to you. The hub is pre-greased would you add any additional grease and if so what kind?
