new ignition now no spark
rangerdave4
had a problem with the soleniod sticking, as suggested i replaced the ignition, i also had the batt tested and its ok, replaced the solenoid, all wires leading to motor and from batt all brand new and clean.
after replacing the ignition switch (6 pole) i have no spark ??/ Hmmmm somethings rotten in denmark :facepalm:
SparkieBoat
Re: new ignition now no spark
you did something wrong, you will have to check all of your wires and make sure you put it back right, also check your kill switch.
