Was performing some maintainance on my 2000 5.0 EFI Alpha I Gen II. Replaced impeller - old one not in bad shape. Since I live where there is alot of sand and mud I flushed motor at both sides of thermostat housing. At first, I was unable to back flush, after some effort was able to back flush on the intake side and I flushed for several min. Last PM I had good water flow on the ear muffs, checked again today prior to dropping in the water and no flow noted. At first I did not see water from the transome so I disconnected the intake (port) side of the T-stat and no water at idle or low RPM, with some throttle (in Nuetral) I did get some sporadic flow. I just re-read the manual and other than not using Permex (I did use perfect seal) I followed directions and I think everything was installed like diagram.
Any thoughts? Thanks Mike
