floatingwoody2006
- Joined
- Feb 2, 2006
- 500
Just bought the boat and motor. It's a 1976 merc 500 in really good shape. Very very clean. Guy i bought it from i know, and he had it on the water last year without issues. He replaced the impellor , plugs, lower unit lube last spring, and it has been used about 4 times since. So..i cleaned her up a bit, changed out poor batt. cables, and just today wanted to hear it run. She fired right up and ran Mint, but after 8 seconds or so, i didn't see a pee stream so i cut it off. There is a rubber nipple where the water should come out from, and i Reeeeally don't want to drop the lower if i have a choice. I don't think i can snake a wire in there to look for obstructions the way it is designed.. Any ideas before i tear into yet another project? There is a flush hole in it, if i get that adaptor, will i see the pee stream?.. Or where does that water go if not partially out the pee hole..
