JB
- Joined
- Mar 25, 2001
- 45,907
I got this PM from Woodnaut on how he fixed a making oil problem. I have added it to the FAQ.
Thanks to Woodnaut for this info.
I would like to submit a comment for your consideration. I was looking at the FAQ section, and particularly at the post on "Making Oil". This is an expert, well organized and lucid explanation of the causes of a four stroke making oil. I happen to have a 2006 Yamaha F90 and had this problem with it. As it turns out, it appears that a significant cause of my engine's problem was that I had it significantly over-propped which lowered by top end RPM to below 5,000. I went back to my old prop, WOT RPM went back up to nearly 6K and the problem instantly went away. The post alludes to this when it talks about combustion, but in my case over-propping caused such a dramatic effect that I wanted to mention it to you. Many Thanks and Best Regards - Woodnaut
