new kawasaki owner.
armenk35
hey guys i bough a 1989 kawasaki 2 seater. it had been sitting for 6 years. i tried to start it and it did start just fine but white stufff like milk came out from the exhust. is that ok or i have a problem? thanks alot
Jeff Walkowiak
Re: new kawasaki owner.
did you have a hose conected and did you turn on the engine before the water like you are supposed to? sounds like water and oil mixed run it and see if it cleans out after a few minutes
armenk35
but where do i connect the hose? its a 1989 can u plz describe where to connect the hose? thank you
Jeff Walkowiak
look for a hose conector with a threaded plug in it,, remove the plug and screw on the hose,, usually near the front of the engine
thumpar
Early Kawi's don't have the hose hookup. If it does have it it would be at the top of the head. I added it to my 1994.
Don't run it for more than 10 seconds without water!!!
