New member, 1991 Gamefisher 15hp
CDM88
Hi all. Recently acquired my first boat, 14ft jon boat with 91 gamefisher 15 hp outboard. I was able to get it running and just replaced a badly damaged water pump impeller. After putting the lower back on, i noticed a black plastic block on the shift linkage that prevents the throttle from advancing past “start” when neutral or reverse is engaged. I can only twist the theottle all the way when in fwd gear. Is this normal or did i throw something out of whack when removing/reinstalling the lower end?
brim_buster
Welcome to the group. Your motor was made by Force and that piece is there to keep you from over rev-ing the motor. The water pump wont pump much in reverse and it keeps you from getting the rpms up and damaging the engine. Very simple motors I had a 88 that was a 9.9hp. Worked well but not a big fan of them
