brandonl87
- Joined
- Apr 15, 2013
- 30
Hey guys, New here and New to owning a boat. I bought a 16ft flats boat with a johnson 30HP with controls. Also Ive tried reading the model an serial number but its pretty much rubbed off ill take a picture and see what you guys think it could be later today. I was wondering about maintenance for it? when should i change the lower unit oil and when to change the water impeller and such. Right now im having a issue with it starting. Took it out a few times now no issues. Yesterday turned the key and nothing happened. like a dead battery. So I put a different battery on and still the same thing. So i jumped from the battery to the starter elimating the control box and it fired right up. So im thinking its the Neutral Saftey switch in the controls. Any suggestions? Not sure how to test the switch other than by passing it and wire it up with out the switch and see if it works.
