1989Carver268
- Joined
- Aug 25, 2022
- 3
Hello All. Glad to be a member here amongst the boating community. I hail from Long Island NY and have lived here more than half a century..
I recently acquired a freebie 89 Carver 268 Pleasure boat w/twin 220hp 4.3 V6's.
Boat is pretty clean inside and practically everything electrical works too plus old owner upgraded all bilge pumps also even added LED lighting in the engine compartment and thats a plus.
The old owner said they knew practically nothing about the boat and that it may have port side engine issues as it smoked heavily...First thing I noticed is there was an LB4 V6 on the starboard side and an L35 on the port side.
Those arent my issues though as Im mechanically inclined and can change out the port side engine in a jiffy to another LB4....
Heres the issue where Im stuck and need the esteemed members of the forums help..
As I go through the boat little things I havent noticed started popping up. Like the outdrives...
First thing I noticed was although theyre both Alpha1 Gen1 outdrives theyre both slightly different and both spin the same way so if both were good I would become a victim to heavy chining but fate steers the ship into the right direction because somehow theres a pretty substantial sized window punched through the lower unit so thats my window of opportunity to get another outdrive but the right one that spins in reverse or even just a proper lower unit from the Marine consignment shop if thats possible...
Heres a picture and on the port side by the tilt strut on the right side of the portside outdrive you can see the window.....
The outdrive thats defunctulated has a serial number of OD339994.
The outdrive Im going to use for the starboard side has a serial number of 6682434
My question is what ratios are both outdrives?..
Another question is what would be the proper reverse rotation outdrive or even just a lower unit that Im going to need for the port side engine that will work with the Alpha1 Gen1 outdrive serial number 6682434?
In my research I nailed down both to be between 1983 and 1990 but when I inquire further about the ratios thats where I get deadlocked...
One time I was doing research there were different revision numbers like Alpha1 Gen1 1.2 and Alpha1 Gen1 1.6 I believe and if someone can clarify the differences in revisions and gear ratios that would be paramount to know at this juncture aswell as knowing.
Thank you all for indulging me and "Thanks" in advance to any and all who contribute with the info I seek as there are still plenty of days here on LI to get it in the water to do a lil fishing...
