Hi there.
We just got a 2002 Key West 1900CC two weeks ago with a 115hp Mercury outboard for recreation and fishing (in salt). This is my first boat, although I've been around them quite a lot, and I'm excited to actually own one finally. I've taken it out twice now over the last two weekends, but now I realize I'm going to have to address a few issues before going out again.
As with most things you buy used, not everything is perfect, and I have a little work to do. Last weekend when I was installing the VHF radio and antenna I noticed that the switch for my navigation lights wasn't even hooked up. I had asked the seller if they worked and took his word for it. He lied, obviously. Last night I took a wiring diagram with me and tried to hook everything back up, but in the end only the transom light was working as far as I could tell. Could it just be the bow light bulbs are burnt out? I didn't have time to check last night, but maybe tomorrow.
The ground to the bilge pump switch wasn't hooked up. This makes me wonder if it works either. How do I test that, fill up the bilge with water and see if it comes on? I better do that on the trailer.
I have to replace the cockpit lights, but I think that switch is hooked up correctly, just needs new bulbs. One of the lights on the trailer is out too, more bulbs.
Last weekend as we were hosing down the boat I noticed one of the dust caps on the trailer wheel hub was missing and there was grease all over the wheel, so I figured I could re-pack it easily enough this weekend and put a new cap on. When I went by the storage facility last night I noticed they had mowed the grass, so now the hub is filled with dirt and grass clippings as well.
Oh, and I've had trouble starting the motor, but I made a separate thread about that. All in all it sounds pretty bad now that I'm typing it all out, but I'm still pretty excited. I just wish I had the time to fix everything during the week, now it looks like I won't be getting out on the water this weekend because of all the work to do.
