new Merc 50 ELPTO overtemp horn test
rubani
is there a procedure to test the overtemp horn circuit on a new Merc 50 ELPTO?
Thanks!
Texasmark
Re: new Merc 50 ELPTO overtemp horn test
Well, Merc uses tan or blue tan wiring for he OT sensor which should be embedded in the water jacket somewhere around the spark plugs location.
You could locate the OT sensor and follow the wire to a junction block or to a bayonet connection if your engine doesn't have a junction block. Either place, turn the ignition key to RUN and short the wire (going to the wiring harness, obviously) or from the terminal block, to the engine block, and you should hear a solid alarm.
Mark
rubani
Mark
Mark,
Found it and did the test. Thanks for the help!!!
