new mercarb
blazer
I have a 1986 I4 3.0L 140 HP M2 Mercarb that needs replacing. Its a 2bbl with one adjusting needle. # 1389-9350. I found a late model 2bbl mercarb off of a 3.0L merc engine. It looks identical in every way. Can I bolt this on?
Thanks
Don S
Re: new mercarb
Can I bolt this on?
Hard to say, give it a try an let us know.
Personally I have never seen any book, manual or anything else that says part number XXXXXXXXXX is a direct replacement for PN 1WhateveryouhaveXX.
External looks means nothing if the insides are different.
Reel Poor
Re: new mercarb
The carb # you posted fits Mercruiser engines serial #6229718 thru C856558 which covers 1982 thru 1989.
Do you have the number from the carb you want to install, or the serial number of the engine it's off of ?
wcsparky05
Re: new mercarb
i have the same engine but an '89, whats a 2bbl and an advusting needle??
blazer
Re: new mercarb
The gentleman selling this carb says it is a MCM 3.0L/3.0XL. The side of the carb says SAE J 1223 Marine. Staped on the carb is the number 864940 21 4712.
