Jiminthekeys
- Joined
- Aug 7, 2012
- 83
I just got my new mercruiser brand manifold and riser in for my 3.0L. I was a bit impressed they came with all the gaskets, new fuel pipe, manifold fittings etc. Could have save 25 buck or so if I new that! guess I have some spare parts to slap some new gaskets on it next year anyway...
My quest is the new manifold and risers came painted. I know this is supposedly some kind of special corrosion protective coating that mercury put on but it looks like the mating surfaces on both the manifold and riser are painted. THey are black anyway... If it is a paint coating on the mating surfaces it is probably very thin because it looks like it would not inhibit a good seal with the gaskets at all. Should I sand the mating surfaces regardless to make them shine? Or would i be find just re-assembling them with the new gaskets and hardware since they are brand spanking new and super smooth?
Also the brass plug fittings for the maifold have a red thread coating on them. Is this already pre coated with the perfect seal? Or do I need to still apply perfect seal? (not sure if the red i'm looking at on the threads is already perfect seal or if it's lock tite or something).
And I also plan on doubling the manifold to head gasket up as stated in my previous thread because of the little bit of corossion pitting I had going on there before. I assume that may not be neccessary but I guess it couldn't hurt either?
Thanks!
Thanks!
