Re: New Motor To Do's
First thing to do it read the owner's manual.
<br /><br />New motors come with gearlube and tilt fluid. Check the gearlube, it's usually a tad low. Also check the trim fluid with the motor fully up. They're usually a bit overfull which is okay. You'll want to add some 2-stroke oil to the oil tank too. Premix a full tank of fresh regular unleaded gas at 50:1 for break-in.<br /><br />Read your owner's manual.
<br /><br />For average use, mount with the antiventialtion plate even with the bottom of the hull. One hole higher for a bit more speed, one hole down for more bite if you frequent rough seas.<br /><br />Read your owners manual.
<br /><br />The rigger is supposed to double-check timing and synchronization as they only ballpark it at the factory. I find they're pretty accurate with their ballparking. If you're not familiar with how to do it, it's probably best left alone.<br /><br />Read your owner's manual.
<br /><br />Don't use regular Silicone to seal the holes, but Ultra Silicones work wonderfully. Seal the motor against the transom and the washers inside the transom. Bolt heads inside the transom on top, on the motor on bottom.<br /><br />Oh yeah, read your owner's manual.
Write the serial and model number inside the cover. On the inside of the back cover, write that you checked the fluids and the date. Keep track of any such maintenace and repairs. Then put it in a Ziplock IN YOUR BOAT! I rarely see owner's manuals in boats! They don't do you much good sitting at home.
