I have searched the forum for information to solve my problem but have not found any. I have a 1980 Mercury 90 HP motor.
Found water in the lower unit oil so I am in the process of changing the oil seals. Doing the prop shaft seals first. Not having the tool to remove the cover nut and remove the bearing carrier, I read and watched a few videos and tried the short cut method of removing the seals. No problem. Ordered new seals using the Mercury diagram part references. The inner seal has an OD of 1.692 inches on the package. It went in just as I expected nice and snug, some gentile taps to get it in place. The outer seal is to big and will not fit inside the bearing carrier. OD of the outer seal is labeled 1.754 inches. I oiled the shaft and put silcon sealant on the bearing carrier, This seal is not going in. I have used a digital caliper to confirm the diameters. My measure of the bearing carrier inside diameter is somewhere between 1.690 and 1.700 inches
Is leaving the bearing carrier in place keeping it from flexing enough to allow the seal to fit? Am I missing something else?
Any assistance will be appreciated
