Just got a 1961 16' Seaswirl runabout - closed bow. The front looks like a tug boat, not much rake to the bow.
It has a 1964 Mont. Ward Sea King 60hp, finally got it running well, but can't really pop out of the hole and top speed is only 24-25 mph (gps). Out of the hole it has some hesitation. Can pull the kids on a tube and skis, but it really doesn't seem like it is running full out.
Pulled the prop, and it has around the shaft "Michigan SMC 864" Stamped on one of the blades it reads (very poorly) "10 1/2 / 8" and looks like it was stamped with just hammer stamps. Is this 10 1/2 inches with an 8 pitch?
Reading about the props for this engine, it seems like this is WAY underpropped, if it is indeed a 10 1/2 inch, 8 inch prop. I see that these pin drive props available now are 10 to 12 pitch.
Still want to ski, but it seems like if it would do better since it can't ever get up to the open throttle rpm's. Tachometer is on order....
Am I reading this right? Would an 11 work better?
