Okay so an update to my power steering woes.
The transom resevoir bottle is 300.00, and if the priority valve is shot they are NLA. So it looks like I am going to go with running 1 pump. The dealer told me that the new twins are running one pump but the other engine still has a pump on it doing nothing?
It must be recirculating or is it run dry, I did ask if they had a shorter belt but he said nope they run a second pump? Is this true and if so how is it plumbed, high pressure side to return and if so does it go through the cooler?
I would think that sounds a bit odd to me I figured they would just use a shorter belt and remove the pump.
Any help with this would be appreciated.
