Rranger
- Joined
- May 18, 2009
- 452
Brought this home on the weekend 13 hour rounder to Biggs Junction Oregon and back to Grand Forks B.C. Got the 1/2” plywood floor 1/2 tore out, had multiple soft spots probably caused by water sloshing around in the two inside hull compartments, for how long that’s been going on who knows. For some reason that water isn’t draining back to the bilge, possible drain holes plugged will see when I remove the entire floor. . Will check the transom out to see if I’m going to be replacing it too. Has fiberglass stringers which appear to be solid so that’s a plus .To big for my garage and carport so can do the rip and tear thing this winter and have it ready for outdoor glassing in the spring. Gonna get cool around here. Johnson has a bad piston and Tohatsu is a runner. I have a 125hp mercury to put on.
