hello all, this is my first post although i've been reading from the sidelines for quite a while...
i have a 19', 1990 Sunbird Corsica 195 with an OMC 3.0. My problem is the top speed is 30 MPH(using a gps), at WOT on smooth water and two people. I'd just like to get where i'm going a little faster without running WOT all the way there. The hole shot seems decent... i get up pretty easily on the wakeboard
Unsure about the prop manufacturer, but it is aluminum with some significant wear on the ends of the blades
Current diameter and pitch is 13x19
WOT RPM is 4700rpm at 30mph
Engine is a 1989 OMC 3.0 140hp. it has some serious blowby, timing is correct, rebuilt carb, runs well overall...havent checked the compression.
Any suggestion are very appreciated. Thanks!
