Nextelbuddy
- Joined
- May 4, 2020
- 156
1996 sea ray 210 mercruiser 5.7 210 hp alpha 1 gen 2 with 1:61 gearing.
according to the sea ray sport boat PDF this is how m boat was originally specced
Year Model Engine Drive Ratio Prop Size WOT RPM
1996 210 BR 5.7L (210 hp) Alpha 1 1.62:1 13.75 x 21 4600
so it originally came with a 13.75 x 21 P prop 3 blade
previous owner installed a mercury quick silver 14 x 19p 3 blade propeller and with this configuration at 4600 RPMs i can only manage about 36-37 mph trim all the way down with full tank of gas. if i trim up, the RPMs will creep up to almost 5000RPMs and i will get maybe 39 mph BUT the boat BOW just hops up and down and its annoying and frustrating so i trim back down and hit my 36 MPH and smooth ride.
i thought i did a lot of research before hand and settled on purchasing a 14x21P aluminum prop 4 blade.... i figured/hoped that by going from 19p to 21p i would gain some top speed back AND some hole shot with the 4 blade.
instead the boat was a slug out of the hole and i can only get about 3000-3300 RPMs max. terrible i didnt even look at the speed on GPS, i could tell the boat was slow out of the hole and with only reaching 3000 rpms top speed was probably around the 25 mph range.
threw the quick silver 14x19p 3 blade and im back to where i was again initially.
so i suppose first thing first is maybe i just have a tired 5.7 engine.. i see other sea ray owners stating they are getting 45-50mph with their 5.7 alpha 1 210 boats. if i am only getting 36 mph at 4600 rpms, my engine must just be tired.
2nd thing is, why did going to a 4 blade 14x21p prop sow me down so badly? should i have tried to go with or find a 13.75x21p like it had from the factory? is there that big of a difference in regards to overall diameter?
what is the correlation between performance and prop diameter?
