New prop needed.
Paintball Freak
I am looking for a new prop for a 1973 85hp Evinrude (2cyl.). however I can't find a site that sells '73 props. Do I need to look for that specific year or would another year's production be compatible w/ this motor?? The prop will mostly be used for water sports and fishing. Any help would be appreciated. :) Thnx
Dhadley
Re: New prop needed.
Supply more info about your rig. What prop are you running now? What is top RPM with an average load? What are you looking for? A stainless prop or an aluminum?<br /><br />Good luck!
Paintball Freak
The motor currently has a 13-3/4x15 aluminum prop on it. As for the RPM it runs around 4000 wide open towing 1 150-180lb. skier. The boat has been in storage for about two years after going through a massive hailstorm and we finally got around to patching the holes in her and getting her seaworthy again. How do they rate the amount of pitch/thrust on a propeller? Is it lower number = more thrust/less speed?? <br />Thanks for all the help :) .
