mr.vrooman
- Joined
- May 2, 2010
- 26
I just got a new aluminum Michigan Match prop for my motor and I have a few questions about proceeding with installation, I removed what was left of the old plastic prop (the hub only) and noticed that the pin that goes through the shaft is slightly bent. I believe this pin would have bent when I hit the rock which destroyed my old prop.
Where do I find a replacement pin for this, can I use anything, or should this be a special type of pin that will shear if I were to impact something else?
If I were to hit another rock, knock on wood, would I completely lose the prop again, or is it designed to shear that pin and save the prop and lower end?
Thanks!
Thanks!
