rustyoletoy
- Joined
- Aug 3, 2004
- 11
I have a 1991 25hp that I want to change the propellor on because one of the blades is damaged. Currently it runs a 11 x 13 3-blade prop.<br /> The boat that the engine sits on is 14' long and weighs around 200lbs. (inflatable) Usually it carries 2 or 3 adults when we go out for the day. Should I stay with the same size prop? It seems to work ok but if I can get better performance, I may as well do it now! <br /> I was thinking about one of those composite blade props (like ProPulse) with variable pitch because that seems like it would let me test to find what works best for me. <br /> Usually I use the boat to go from point A to point B and explore but sometimes I want to pull stuff or fish or stuff so a do-everything prop is what I want.
<br /> Also everything that I read says you should keep the engine between certain RPMs. How do I figure that out on my engine? I have a dwell/tach meter that I used to use for tune-ups on an old car I had, can I hook that up temporarily and if so where?<br /><br /> Sean
