honda460ex
- Joined
- May 12, 2011
- 69
Lol, my saga never ends... To anyone who has followed my troubles with the vacuum issue I had recently, the motor is running great now! But I have another issue...
I noticed a while back when testing on muffs the voltage would rise and rise the longer the boat idled. Figured the rectifier was bad. Replaced it. Still an issue. Bought a CDI rectifier next time around. Still overcharging. Before all of this though I replaced the stator with a CDI stator and the trigger also with a CDI (which was the cause of my vacuum issue from another post). The trigger was wired incorrectly from the manufacturer and I temporarily have the wiring compensated on the outboard until I can work something out with CDI. The way the trigger is wired runs fine now though. I just swapped a couple of wires around off of the powerpacks to compensate for CDI's screw up.
Back to the problem though. I replaced the battery today with a brand new one and I am still having the overcharging issue. I hate to even ask this question, but could it be possible that I got a bad stator from CDI as well?
I am heading back out to the garage in a minute just to double check all of my grounds, but I don't think that is it.
I can remove one of the yellow wires from the stator to the rectifier and the charging will drop back down to 12.4-12.5 and keep the battery charging it seems.
Thoughts all?
Thanks in advance!
Thoughts all?
Thanks in advance!
