I hooked the battery up backwards and blew my old rectifier.
I installed a new one from brp.
Now it overcharges, 17 volts or better.
The stator test for ohms reads correctly and the motor runs strong (after full rebuild).
The new rectifier reads kilo ohms for a brief second and then opens up, in one direction only.
The test perameters from seloc are vague, it doesn't say if the rectifier should maintain continuity or if as I find, continuity for a split second then nothing.
Could it be a bad new rectifier?
Maybe something else I'm missing?
I don't remember gronding the stator, is there a ground under the flywheel?
I don't want to take it off if I don't have to.
