2008 Mercruiser 5.0 liter TKS Alpha 1 Gen 2 Raw water cooled.
Engine begins running hot over 3000 rpms. If you back off it will cool down. Will run at normal temp all day as long as rpms are under 3000.
Here's what I've done so far.
1 Changed manifolds and risers. They were 8 years old anyway.
2 Changed thermostat. Old one was ok
3 Changed impeller twice in one season. Old ones were ok. No pieces missing on either impeller.
4 Changed impeller housing with new model SS type with rubber gaskets attached to plate. Did not use any sealer on gaskets.
5 Changed exhaust flappers. old ones were intact.
6 Back flushed power steering cooler when everything was apart. nothing inside.
Here's what I haven't done.
1 Install a clear hose from thermostat housing to starboard manifold to see if there is air mixed with water as per Merc bulletin.
2 Change engine mounted circulating pump. I heard they rarely fail and if they do, usually cause a low rpm overheat.
Is there anything else to check? Has anyone had this issue?
Thanks for your help.
