I am having starter troubles on my boat. Engine is about a 2000 model 5.7l carb engine. Towards the end of the season last year the starter started to sound bad. It got to a point where if it cranked for more than a couple seconds the appendix would disengage from the flywheel and just spin. If you let off of the key and try again it would turn the engine over for a few seconds before disengaging again. It would always spin, just not turn the engine over.
I ordered a cheap marine starter and tried it and the appendix would not engage at all when testing it on the bench before installing. It would only spin but the appendix would not come out.
I sent it back and ordered a new Sierra starter and am having the same issue with it. I am only grounding the starter and adding power directly to the terminal going from the solenoid to the case of the starter. The starter spins just fine but the appendix wont come out. I also tried doing the same thing to my old original starter and it is doing the same thing as the two new ones.
Am I jumping the solenoid wrong or did I just get 2 bad starters in a row? I know it is possible but doesnt seem very likely.
