new spark plug fouled and oily, motor won't run right 1999 Merc 125hp please help!
mallardtone-man
hey guys I have a 1999 mercury 125 hp outboard that I recently purchased and have been having some trouble With. the short story is I have run the motor probably 20 hours so far and thought it was running pretty good a couple of times. Did stall on me while at low idle. I replace the spark plugs 2 days ago. when I pulled the old ones they were all pretty dirty but did not look oily or gunked up. none looked worse than the others that I could tell. I took it out to the water shortly afterwards and could get it started but it wouldn't run right. it would start on the first crank withouthaving to choke it or lift the warm up lever. it would run for around 30 seconds strong at first then Peter off and stall. I can get it to stay running if I lift the warm up lever however it sounds like it is at around half power and might be misfiring. I pulled the plug out today and the first second and fourth ones were all clean but the third was badly fouled looked oily. also it looks like there is some well for gas and oil coming out off the and of the prop 4 somewhere near there. I am very concerned about this and have to try my hardest to get it fixed in the next two days as I am supposed to be taking the boat on vacation for a week. can you guys please give me any advice you have on what issue might be or what I should do to further diagnosis. should I run a compression test?
just a quick side note I just postedabout the fact that I ran out of gas a couple of times and had a lot of trouble getting it restarted. the only way I could get it started was with the warm up lever all the way up at first it would seem to be doing the same thing it is doing now, but after running it like this for 5 minutes or so would roar back to life and resume normal function. I was told that this is because the carbs had emptied and needed to refill themselves, just thought it was worth mentioning since it is behaving exactly like it was before just not coming back to full Power any more.
I really need you guys on this one please tell me it is something I can manage. I am very mechanically inclined just have little or no experience with boat motors. Thanks so much for any help James
flyingscott
When you posted out of gas you did not mention the other problems you need to either rebuild or clean your carbs you possibly have one or more flooding the motor if you rebuild them make sure you get the new accelerator pumps for them check for spark and compression
