Re: New Speed Tubes
D_Wilson...
You say speed tubes are easy to remove. I have a Futura that I bought used, so I don't have the manual. One of my speed tubes leaks - losing most of its air within a few hours. I have wanted to repair it, but I can't figure out how to remove them. Any hints???
Yeah, they are very easy to remove and replace.
1. Take off the valve cap.
2. Remove the valve insert.
3. Then you either need a large socket head or (like me) use a decent pair of channel lock pliers to remove the valve seat (female end). It turns counter-clockwise to loosen. You'll then be able to push the male end down and pull the speed tube out the back. It reassembles the same way in reverse.
I orderd some rubber gaskets from a dealer because I had air leaking right on the valve seat. You may need to do the same. I also use a bit of Permatex #2 on the assembly when I put it back together. It helps seal and is easy enough to remove.
One of my tubes is still leaking so I'm looking to replace them both after the season ends (one more month here). If anyone knows of the cheapest place I can get them I'd appreciate the tip.
Good luck and post your results.
