Boat is a 1998 Bayliner 1850LS 3.0L 4-cyl gas engine
This Spring the boat lift failed with boat on the lift. Of course the drain plug was out and the lift and boat bottomed out. The engine compart was about 1/3 full of water. I drained the water, replaced the oil and filter. The started worked most of the time, but occassionally would only have the solenoid click. If I kept trying the starter would kick in and start. I replaced the started/solenoid combinbation and a new battery. Now the solenoid ONLY clicks and there is no attempt in the starter trying to engage.
The old starter had three lugs on it. One for the switch wire, another for the battery wire, and the third was pre-wired going to the starter. The new new has four lugs. One for the switch wire, another for the battery wire, one pre-wired going to the starter, and according to the company the fourth is used on OLD systems needing a wire going to the coil. I was told to leave this lug empty.
Any ideas or suggestions? I can send pictures if that would help anyone.
Ron
Ron
