This is a 16 foot runabout restoration. I spent most of yesterday grinding away the old stringer tabbing, and am trying to figure out the new structure. The OEM had two 2? x 3? suspended off the hull with the tabbing, ?? plywood deck, poured foam. I wasn?t planning to use poured foam, so do I need more stringers to help stiffen the hull? Lots of work to get all four stringers level if they all contact the floor. Maybe two of the stringers aren?t full floor height, just glassed over stiffeners? Seems like a few bulks, one at each plywood joint (3 joints) might be in order too (?). Or, use poured foam again? I can see the value of poured foam because it does provide twisting rigidity, floor support, and hull stiffness. The floor width at the widest point (transom) is 58 inches. Head scratching going on ? ideas and advice welcome
Thanks for reading
Brian
Thanks for reading
Brian
