New Style Gimbal Bearing Zerk Fitting Plug
RC54
Put in a new style gimbal bearing that came in a kit with U joint bellows, exhaust bellows, etc. Since I replaced my gimbal bearing with the new style I need to remove the grease fitting and install a plug. I did some research on the plug and ordered what I thought was the correct part but it doesn't fit...wrong threads, I believe.
Does anyone have the correct part number for this plug? The part number I ordered is 10-8M2015913.
Thanks...Randy
Bt Doctur
I`d just leave the fitting and cap it. Dont think any water will get thru a 4 inch hole filled with grease
wellcraft-classic210
Its a 10-32 thread most likely -- Might want to try a short screw -- Stainless with a tread sealer would probably be best
RC54
Thanks guys, I think I will try the screw trick, since I already have the fitting out.
Man, that little slippery grease fitting is a ***** to try and get restarted back in that tiny, inset hole!
Ayuh,...... Grease fittin's are either 1/4"- 28, or 1/8"- pipe thread,......
Or,..... Metric,......
'n that 1 is not 1/8" pipe,.....
Edit: part number 10-8M2015913 is PLUG, (.250-28 x .320) (#10-8M2015913)
Comment: (Use with non-greased bearing)...
While FITTING For Grease is (# 22-74036)
Comment: (Use with greased bearing)
achris
More fish than mountain goat
Blank off plug should have been in the box with the new bearing. Check the floor where you unboxed it. It uses a Torx head screw. Can't remember the size.
