Hi
I have a question about the normal cooling operation. I have a Mercury thunder bolt 900 think 1978 it is a 6 cyl. At idle no pee stream if you increase the speed it seems to pee strong. Looked at manual it shows a thermostat will open at a certain temp. Does that mean no pee until the thermostat opens our should you see water peeing all the time. I may order a water pump rebuild kit to be safe. Any other ideas would be welcome or other issues I should be on the lookout for with this motor. All other outboards I have owned no pee replace impeller.
thanks win231
thanks win231
