New to boating ... few questions
orbitz
Hello all, seems like a great boating community you have here.
Just purchased a 1994 Bayliner Capri 1950, running condition, but I decided I'd perform some preventative maintenance before taking it out to keep it that way. So far, I have replaced the spark plugs, the engine oil and filter, the gear oil, and purchased a new battery. Someone had mentioned cleaning the carb and possible looking into a new oil / fuel filter? Can anyone confirm this and list a few other things I should probably do? Any suggestions are greatly appreciated.
Thanks!
maharg
Re: New to boating ... few questions
Do you know when the bellows, belts, and impeller were last done?
Make sure the bilge pump works too
Andy'sDelight
What the above said, as well as the fuel/water separator (highly recommend installing one if it isn't there already), and don't neglect the trailer. Nothing sucks worse than driving a perfect, ready to launch, boat only to find out halfway there the bearings give out and leave you on the side of the road or worse.
H20Rat
what kind of engine? (if i'm not mistaken, that 1950 came as both an outboard as well as I/O setup?)
INJUN
If you don't have one, get a safe boating certificate. Many states require it.
orbitz
Bilge / Blower works. Not sure when bellows, belts or impeller were last done.
Not to worry ;). I forgot to mention I pulled out the ol grease gun and greased the trailer bearings and grease nipples on the stern drive (which i'm assuming relate to the trim).
Mercruiser 3.0LX Alpha One II Sterndrive
orbitz
I'm in Canada, although not a bad idea given I'm in a border town separated by the St Marys River and Lake Superior, so I'm sure I'll see the U.S. Coast Guard more than once ;).
By the way, I noticed the bolts on the valve cover were a little loose and I was thinking I should probably change the valve cover gasket, but I'm not quite sure where to get one. Anyone know of an online store?
maharg
You may actually want to inspect the bearings.
Thad
There should be a grease zirk inside as well. Look behind the engine.
My Mercruiser had on there. And if I remember right, there were three on the outdrive.
Scorpion210
You do require your Boater's card in Ontario too. They became mandatory in Sept 2009
orbitz
Sorry, the term certificate (above) confused me. I have my pleasure craft operators card (canadian boating license).
Anyone know where to get a valve cover gasket for a 94 Mercruiser Alpha One 3.0L/LX
orbitz
Thanks so much! Only issue is, I don't know which one I need for a Mercruiser 3.0L LX Alpha One II 4 Cylinder.. there are a few mercruisers listed..
Thad
Put a new thread in engine repair. Give any and all information on the engine, year, any numbers you can find on the intake and they will have you set up in no time.
