Will correct myself about the information about that all 1989 has the same impeller.
1989 came with both 1 and 2 piece drive shafts LU.
Yes your engine has the two piece drive shaft and the 89984T3 is the impeller, but a preowner could have change it.
But as you mention about the impeller bag it seems it is th two piece drive shaft model.
OEM manual is the best and OB4842 (85, 90 and 125Hp 1988 through 1991 A models) should cover your engine.
Not the L drive model if it that you mean with L models.
Check out at Ebay, they comes up there.
