Hi All,
I just bought a new to me 1990 Sea Ray 160 bow rider with a 3.0 mercruiser and alpha one drive... The unit supposedly has very low hours, and the condition of the boat supports this.
The previous owner changed the engine and gearcase oil every fall and did his own winterizing (it was a Minnesota boat). The engine oil looks brand new. In his paper work there was the receipt for oil and filter from last fall.
The boat runs good... maybe a bit of rough idle, but not awful. This is my first I/O boat, and I can hear minor bearing type noise when the engine is running. This noise changes a wee bit when the drive is turned stop to stop, but there is no clicking or clunking or anything like that. Maybe the sound is completely normal (?), but I'm concerned it could be either a worn or under-lubricated gimbal bearing (?).
The previous owner said the drive had never been off the boat in the 5 years he owned, and he didn't know about before then. My guess is it's had oil changes done but nothing else.
So here's my Q:
Given the info I've given you, what should I do to the boat maintenance-wise before I take it to the lake for the summer holidays? (which we start in 3 weeks)
My thoughts are:
1) Replace impeller for sure
2) Probably would be wise to pull the drive and inspect the gimbal bearing and U-joints. They would be replaced if necessary, or at least would get greased.
3) If I pull the drive, I think I'd change out the bellows.. this boat will be moored for the summer.
4) New set of spark plugs.
What do you think about 2 and 3? Absolutely? Good idea? or am I too uptight?
FYI, I plan to do all work myself... I've done significant work on outboards before (rebuilt lower units etc)... but this would be my first real wrenching on an I/O. My Dad had one until a couple years ago and had replaced U-joints and gimbal bearing on his mercruiser more than once... so it can't be that bad. (famous last words
thanks for your $.02
So here's my Q:
My thoughts are:
