Re: New to me 1993 25HP Mercury
Most Quicksilver boxes are pretty universal, obviously you don't need to spend extra on one with a T$T switch...due to your motor not having it. Unless you added a aftermarket tilt and trim system. Non T&T boxes will just have the standard black motor electrical connector, ones with T&T will have the same connector, just with 2 extra wires hanging off the connector. If you get one of those, just put the extra wires out of the way. Cables are the same. I think the best one to get would be a Commander 2000 series, it's a standard side mount control box with the ignition swith built in. Just mount it, hook up the cables to the motor, plug up the electrical connector, wire to a battery with your motor's cables and off you go. They make the Commander boxes with or without the T&T switch built into the handle.
