New to me Regal W/4.3L GL & SX-M
cptbill
Just picked up a 2000 Regal 2760 Commodore at a price I could not pass up(3L GLPWTR, SX-M) . It's been used as a live aboard and just sat at the marina, anyway I'm pulling out to start my rehab and one of the top things is to replace the out drives. One is total junk and the other I might be able to save with a little luck. I am planning on going to Duo props and I've read most of the older threads on the subject but I have a tendency to over think things, so just to be clear The DP for the replacement should be DP-SM 1:95:1 and if I find a dp with the incorrect ratio the change can be made in the lower unit, all the uppers(for the most part are the same)
QBhoy
Your title says 4.3 but the description says 3.0. Not sure if mate any big DP outdrive to a 3.0. Be a waste of money and time I’d think.
cptbill
My bad 4.3L GL PWTR, from the research I've done a DP SM 1.95 3868913 should bolt right up and be the right gear ratio. Started rebuilding one last week. need to find another one
