As my restoration continues, I need to learn about the subject device which is feeding the 1988 2.5L motor.
My approach is to check it frequently for water initially and then taper back to every 20 hours or so.
If it fills with water does it prevent fuel flow, or do you get a fuel/water mixture going to the carb?
Is there an anti-siphon device anywhere between the fuel tank pickup and the fuel pump? I was thinking the subject filter may have a back-flow preventer of some type.
Thanks,
Richard
p.s. After changing out the starter and the starter slave solenoid, the engine fires up nicely and idles smooth at 9000 RPM. Everything is going well so far. I haven't pulled the fuel filter yet to see if there is much water in it. Idle time is only several minutes so far.
Thanks,
Richard
