kssmallies
- Joined
- Aug 31, 2007
- 8
Hi, Iam new to this forum and just bought a cheap bass boat and really don't know anything about the motor. I do know it is a Mercury 500 50 hp. On the motor registration paper it says its a 1971 but the local boat mechanic says its a 1967? Don't know which is right but I do know I have a problem. I can get the motor to start and run pretty good but I can't go fast. ITs like the motor revs up when I throttle down but I stay the same speed which is a little faster then what the 30 lb thrust trolling motor goes. I put the idle up and throttle as far down as it will go and the motor revs way up but the boat just keeps the same speed when I idle down though it slows down. Someone told me I may have spun the hub? I don't know what that means and how to fix it? Do I buy a new prop or a new hub? And I took the prop off and don't know where to look for the hub is it inside the prop? Anyways any suggestions would help a whole lot I don't know if the spun hub is the problem or if I need to clean or rebuild the carb or what anything would help. Also I changed the lower unit oil and I bought 1 quart and Ifilled from the bottom till it ran out the top and I still have over 3/4 of the quart left is that normal or should it have used the whole bottle or at least half of it. THanks
