New to site
The Rez
Hello folks i just found this site while looking up a boat i just got a Thunderbird Shawnee with cathedral hull (i thought it was called a tri ) dont know much about them but i think i found the right site for questions. One question I have for you fols is a mercury 850 worth putting money into?
Home Cookin'
Re: New to site
an old merc on an old boat looks good--but you are in the restoration hobby stage--think about a vintage sports car. Stuff will go wrong, nad require tinkering--time money and skills. if you want something dependable "starts first time every time" then you need to plunk down the green for a newer motor.
Mercs can be very tempermental and it's hard to find skilled mechanics who know the old ones. They were in some areas internally inconsistent from year to year as Kiekhoffer tweaked them. They were fast and popular with the speed guys, not the work horse guys. "If you want to get there, get a merc; if you want to get home, get a johnson."
Lots of boats from the late sixties on were called "tri-hulls" and cathedral hulls. Actually, very few true tri-hulls were made; they weren't too successful because the angles, etc. were severe. All three "hulls" where they hit the water were about the same size. The cathedral is a softened tri-hull, with the center "hull" deeper. So the classic Whaler is pretty close to cathedral and some people nowadays refer to them as tri-hull, and they are comparable until you get real technical.
JoLin
Re: New to site
Trihull, trihedral, cathedral... all about the same. Welcome to iboats!
Frank Acampora
Re: New to site
If you want to get there, use a Mercury. If you want to get back use a Johnson---OR get a Sears and rowback.
Trihull, cathedral--AKA "waveslappers"
The Rez
Re: New to site
View attachment 182310 Does it look something like this?
Yes it does, Got motor on stand needs some help took cover off choke rod broken, deep gouge in lower end, carbs missing screws, Not a good sign, power cable in need of replacing, turns free and paint is good I guess they are the only things good so far. I guess it's going to scrap!
The Rez
Re: New to site
the worst you can do is get a price for all the parts
Well it took some time going over this thing the words kept coming up (Discontinued part) time to price out motors
Ouch this is going to sink things.
ezmobee
Re: New to site
Unfortunately Mercury parts support doesn't seem to be as good as Johnson/Evinrudes going back. You can still get just about every nut bolt and screw for '78 and newer J/E's, and darn near every one for '73 and newer.
spdracr39
Re: New to site
Welcome !!! It's always more expensive to restore old stuff than fix new stuff. It just depends on what your goal and use for the boat is.
southkogs
Re: New to site
... or just re-power. Some of those 2cly Evinrude 50's come pretty cheap. I used to run one on a 15' and 6 gallons of gas would get you a LOT of time out on the lake.
The Rez
Re: New to site
Thanks for the information. I guess I will take my other questions to the Eng topics.
littlerayray
Re: New to site
just make sure you dont overpower it or bye bye transom seen my buddy row back home cuz he put a 250 outboard when the boat was only rated for 175
