Re: New to small boats.
The other prop I have is only a 15 pitch but its also a 15 dia. If I go up in dia and drop pitch it should keep my rpm around the same? I've got to take my gps next time out and check my speedo.
This boat has never run in salt water. I bought it to use strickly in salt water. What anodes do I need? Are there anodes that go in the engine/manifolds as well?
With sterndrives the diameter (more or less) is set by the manufacturer of the prop... You buy the pitch you want, and the diameter is more or less fixed... and only changes less than an inch from a 13" pitch to a 23" pitch... Each inch of pitch change will change the engine WOT by about 200 rpm....
Some general information about your engine...
MCM120 - 2.5 litre (153 cubic inch) 4 cylinder in-line engine, made by GM.
Recommended WOT - 4200 to 4600 rpm. (if you're getting a genuine 4700 with the 17" prop... leave that one on... It 'light loads' the engine, making it run better, and it's more 'driveable'... Mine tops out on the rev limiter, 4950.... Love the way that boat handles... You could use a little trim UP, you might find the revs going higher (and the speed, sure you can handle it....
) In that case change to a 19" pitch prop...)
Drive.
Model designation - MR (Please, please, NEVER use the term 'pre-alpha'.... there is no such thing, and people like me go bananas when we see it)...
Ratio - 1.98:1
Given the engine speed and prop pitch you gave in the first post, my prop calculator indicates something is not right... Either your tacho is reading high, or the speedo is reading low... Did you use a GPS? Also check the calibration on your tacho. Most dash tachos just aren't accurate enough, you need a 'shop' tacho...
My temp is staying at 125 after an hour of running so I'd say that's acceptable. What should my oil pressure be at. It was like 58/60 initially then dropped back to 40 lbs after it warmed up. I was going to add some Lucas oil treatment to it. Is that a good idea? I run it in most of my small engines.
Temperature sounds too low... Check there is a thermostat installed... Some idiots take them out :facepalm: I have no idea what they're thinking (or if they are even thinking!).... If the thermostat is there, check it's working properly. Easier probably to just throw a new one in... Oil pressure sounds about right.
Spec for thermostat is 143?... Oil pressure spec is 4 psi at idle (minimum) and 30-60 at 2000rpm.
And just use the normal anodes supplied by your local friendly dealer (and they're getting harder to find too...
Apparently I'm new to this forum as well. My last post came up twice. Is there a way to delete them?
Yes, you're new... (which is why everyone is so nice to you...
... Wait until you're an old fart like me... Then you get abused up hill and down dale...
The moderators are the only ones who can delete posts... The magic 'zap' button... Used to get used on me lots, in the bad ol' days...
Chris........
